Hey qlv,
It looks like you don’t have access to the SSH on the Raspberry Pi yet, so were you running the I2C detect command on your own computer rather than the raspberry pi. Are you using windows or Mac. If you are using windows, have you installed the Bonjour from here: https://support.apple.com/downloads/Bonjour_for_Windows. Also, what image are you using with the Raspberry pi.
Hey QY,
dex.local only works with the Raspbian for Robots image from Dexter Industries. It also comes loaded with all the software and packages so that you are ready to run them.
Hey QY,
If you have SSH access to the Pi, you should definitely run this: https://www.youtube.com/watch?v=ZMadpIEYq5o&list=PLGXEJ4Ye1qCMWziVrynnrIPpgfOr-2aj9&index=4 and upload the log here. We can easily look at the state of the GrovePi and what has to be done to make it work again by looking at the log. It might be something as simple as resetting the GrovePi from the software, or might require a firmware update.
Hey QY,
It looks like the firmware on the chip is not working properly or might have been erased accidentally. Can you follow the guide here to install the firmware: https://www.youtube.com/watch?v=VUVvU4YcTvo. This should solve the problem.
I’m a member in Quanyang’s project. I tried to follow the guide on the Youtube. However, we are still unable to connect to http://dex.local. Last time you asked us what image we are using. So the system we are using is the system recommended by the official guide (https://www.raspberrypi.org/help/noobs-setup/). We downloaded and installed the system by ourselves. Today we also tried downloading the image you recommended(http://www.dexterindustries.com/howto/install-raspbian-for-robots-image-on-an-sd-card/). But after we completed all the installation steps and tried to run the new SD card, there was no signal sent to the monitor. We have checked that the monitor works well if we use the old system. But for the new system, it doesn’t work. Could you please check if the newest image is correct? And is there any other simple way to check? Currently we are directly using raspberry pi as we don’t know if we can connect Grove Pi to our own laptop and how to do that.
Hey yushengz,
When you enter the SD card into the computer, what drive is mounted. Can you attach a screenshot of what you see there. Also, what happens to the LED’s on the Raspberry Pi when you put the SD card on it and power on the Raspbbery Pi. Can you attach a picture of your raspberry pi setup connected to the monitor.
I’ve also been facing a similar problem. The grovepi+ module operates perfectly when I use a raspbian wheezy installed sd card. However when I tried another sd card with jessie lite both the reset and pwr leds stayed on and there was no 04 in the “sudo i2cdetect -y 1” output. When I tried to update the firmware there was an error message saying “avrdude: Can’t find programmer id gpio”. I also noticed that every time I ran install.sh, the pi uninstalled python-rpi.gpio and then reinstalled it. Besides this there was no abnormal response.
But, as I said earlier, the system runs perfectly if I switch the sd card back to wheezy. I wanted to upgrade the os as I use other apps on the pi and have been trying to integrate sensor inputs from grove.
Is jessie lite not supported yet or can I use the full blown jessie?
Hey s.roy,
We are still working on getting our image and software to work on Jessie. Rigtn now running the software and install scripts on Jessie is not supported. We haven’t seen a lot of programs which don;t work on Jessie and you should be able to use most of them with our latest Raspbian for robots image. Can you tell us about the software which you are trying to use with Jessie.
I’m not doing anything specific and I’m not an expert either. Just googling the net for apps and testing out their functionality. Basically I’m still trying to learn to capture sensor data and use it productively. This reminds me to ask is there any way to map gpio pins to grove sensors? How can I transfer data from grove sensor to a shell script which expects data from a particular gpio pin? An example will be much appreciated.
Also, do let me know if you need any sort of assistance. I don’t know if I’ll be able to do much but I’ll surely try my best to help
