I2cdetect -y 1 cannot detect any port
Hi
Im new for raspberry pi and grobepi.
Raspbian For Robots was installed to my raspberry pi 3B by http://www.dexterindustries.com/GrovePi/get-started-with-the-grovepi/.
Until I started to test the grovepi.
When I tried “cd Desktop/GrovePi/Software/Python/” and “sudo python grove_firmware_version_check.py”, the system report me
\Traceback (most recent call last):
File “grove_firmware_version_check.py”, line 40, in <module>
print(“grovepi has firmware wersion: %s” %grovepi.version())
File “/home/pi/Desktop/Grovepi/Software/python/grovepi.py”, line 258, in version
return “%s.%s.%s” % (number[1],number[2],number[3])
TypeError: ‘int’ object has no attribute ‘getitem’
Then I update the firmware by following https://www.youtube.com/watch?v=VUVvU4YcTvo
And i also checked sudo i2cdetect -y 1 but there was no i2c found
by the problem still be occurred.
please help
Thank
Hey Tinna,
Can you follow the instructions here and run the troubleshooting script for the GrovePi and upload log here: https://www.youtube.com/watch?v=ZMadpIEYq5o. That would really help us to solve the problem.
Hi Karan
I followed your instruction.
And this is the detail in a log file
Check space left
/dev/root 3.6G 2.7G 729M 79% /
devtmpfs 427M 0 427M 0% /dev
tmpfs 432M 0 432M 0% /dev/shm
tmpfs 432M 6.2M 425M 2% /run
/dev/mmcblk0p1 60M 21M 40M 35% /boot
tmpfs 87M 0 87M 0% /run/user/1000
Check for dependencies
python-rpi.gpio 0.6.2~jessie-1 install ok installed
arduino 2:1.0.5+dfsg2-4 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.32
Raspberry Pi Details:
  • Device tree is enabled.
  • This Raspberry Pi supports user-level GPIO access.
    -> ie. export WIRINGPI_GPIOMEM=1
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 004: ID 046d:c05a Logitech, Inc. M90/M100 Optical Mouse
Bus 001 Device 005: ID 1a2c:2124 China Resource Semico Co., Ltd
|__ Port 3: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 5, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 5: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
Raspbian for Robots Version
V 6.9
This version of Raspbian was modified by Dexter Industries on the Wheezy Raspbian Build.
This version was updated on 2016.03.20
Hostname
dex
Checking for Atmega chip
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size ‪#‎Pages‬ MinW MaxW ReadBack
Programmer Type : GPIO
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0’ or/dev/i2c/0’: No such file or directory
Checking I2C bus 1
70: – -- – -- – -- – --
Checking for firmware version
File “/home/pi/Desktop/GrovePi/Software/Python/grove_firmware_version_check.py”, line 40, in <module>
print(“GrovePi has firmware version: %s” %grovepi.version())
File “/home/pi/Desktop/GrovePi/Software/Python/grovepi.py”, line 258, in version
return “%s.%s.%s” % (number[1], number[2], number[3])
Looks like the firmware is not responding on the GrovePi. Can you follow the instructions here to update the firmware: http://www.dexterindustries.com/GrovePi/get-started-with-the-grovepi/updating-firmware/ and see if it works.
I updated firmware already but there was no change.
the troubleshooting still showed the same result.
However, the rst light and pwd light always light up. I think there is something wrong with my GrovePi board.
Hi Tinna, since you’re running Raspbian for Robots, is it possible to try this: https://www.youtube.com/watch?v=VUVvU4YcTvo&feature=youtu.be
This is a more visual guide to updating the firmware.
I did everything with your instruction but the grovePi still be detected by raspberry Pi.
This is the result.
Check space left
wiringPi Found
wiringPi Found
Hardware revision
gpio version: 2.32
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
V 6.9
Hostname
dex
System wide configuration file is “/etc/avrdude.conf”
User configuration file is “/root/.avrduderc”
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Checking I2C bus 0
Error: Could not open file /dev/i2c-0’ or/dev/i2c/0′: No such file or directory
Checking I2C bus 1
00: — — — — — — — — — — — — —
10: — — — — — — — — — — — — — — — —
20: — — — — — — — — — — — — — — — —
30: — — — — — — — — — — — — — — — —
40: — — — — — — — — — — — — — — — —
50: — — — — — — — — — — — — — — — —
60: — — — — — — — — — — — — — — — —
70: — — — — — — — —
Please help me
Can you upload a picture of your GrovePi and how it is connected to the Raspberry Pi. Also, can you upload what you get on the terminal when you do the firmware update with the instructions here: http://www.dexterindustries.com/GrovePi/get-started-with-the-grovepi/updating-firmware/.
