This should make the motors move forward for 5 second, then stop for 2 seconds then back for 5 seconds and again stop for 2 seconds and repeat the whole process. The LED light should also turn on and off. Do let us know if this works for you or not.
Hey Aro, thanks for posting this video. It really does look like that motor is somehow resetting the board; maybe something is shorting the GoPiGo board out, I’m not sure. And when you just attach the right motor, that seems to be working just fine.
I think you’ve been in touch with Taryn, no? We will send you a replacement right away. Sorry for the troubles and thanks for working with us for so long. I think the best thing to come out of this thread is the hardware test, which will hopefully help us sort out issues for folks faster in the future. Thank you so much!
First of all, thanks for sending me the new motor. However I have bad news, it looks like the replacement motor gives me the same exact behavior as the bad motor.
As far as I can tell, right now I have 2 bad motors and 1 good one. The good one passes the hardware test both when connected to the right port as well as when connected to the left port.
The two bad motors (one of them is the replacement), look like they short/reset the board, when connect to either the left or the right port (see video IMG_1267.mov from a few posts back).
Any clue as to what’s going on? Just another bad motor or something else?
I got the second motor today and I still have the same problem. It makes me suspect there is something deeper going wrong…maybe something with the board?
Maybe at this point the best thing to do is send an entire replacement or a refund (unless you see any other debugging I can do on my side). I can return the gopigo I currently have (and the two replacement motors) with the prepaid postage that Amber sent me.
Hello Aro, We can proceed any way you like. If you’d like a full refund at this point, we’ll try to arrange that. If you’d like a full replacement at this point, we can try to arrange that. Just tell us how you’d like to proceed.
Thanks for the quick response John and for the great customer service. I would appreciate a full replacement.
I’m really stumped as to what is causing the problem. As far as I can tell, the one good motor plugged into either the left or right side works correctly, but if I use any of the other three motors (on either side, alone or with another motor) then the board seems to get reset (i.e. any LEDs that are on turn off and the motor stops). I’m really curious what the difference is between the “good” motor and the other three and/or why the gopigo board behaves differently depending on which motor is plugged in.
I can label the motors and send them back to you (along with the rest of the gopigo I currently have). If you figure out what the problem is, please make sure to let me know
Hey Aro, we’ll keep working with it if you’ll keep working with it. I would like to get this back and see where the defect is. We’re constantly working with our manufacturers to improve the testing, maybe it’s something we can prevent with some testing in the future.
I’ll alert Amber, we’ll get a full replacement to you. Thanks for your patience with this.
Hey John, I got the new replacement and it works like a charm!
I did a few simple tests as well:
1.) I tried the new board with the old motors – this gave the same problems I was dealing with before.
2.) I tried the new motors with the old board – this works great!
So, indeed, it seems like the trouble is with the motors (one that came with my original purchase, and two replacement motors). I just thought it’s very unlikely that I’d get three problematic motors.
I’m happy with using the board from my original purchase plus the two motors I received in the replacement package. If you’d like, I can send back the other motors (as well as the extra replacement parts); just let me know how.
I wanted to reply to this thread because I believe I might be having the same issue. Understand that I am very new to this programming environment but I can add a bit of detail.
At random and for unknown reasons the right servo motor rotates at an inconsistent speed relative to the left motor. Things investigated:
1.) The wheel, fly wheel, and servo are clear of any obstruction.
2.) Using the basic_robot.py example script, I can manipulate the servos. The issue occurs in both forward and reverse, but not when activating right.
3.) When I adjust the speed either up or down, both the servos adjust and begin moving at the same speed even if from a dead stop.
Hey hermiesterbergerbergermiester,
Have you done the software and firmware update on your GoPiGo. We used to see this problem a while back with the older firmware but it should be solved with the new firmware and software.
I just received a GoPiGo last week. I upgraded the s/w and f/w. F/w version is 1.3. Battery level is good at 10.7 Volts.
I’m running a very simple 3 line script and I’m seeing inconsistent behaviour. Here is the code:
from gopigo import *
enc_tgt(1,1,72)
fwd()
Sometimes when I run the script the robot goes 4 revolutions and then stops (good).
Other times I run the script the robot does nothing.
And yet other times I run the script the motors start running and never stop. In this case, I have to run another script to issue the stop() command.
Hey capple, just a quick update: we’re still working on this. We think the problem is at the firmware level and we’re taking a deep dive into it. Just wanted to give you an update on this.
Seems to have gotten worse with the f/w update. Each time I power up the GoPiGo with version 1.5, the left motor spins the wheel for a few seconds and then stops (right motor is fine).
I tried running Software/Python/other_scripts/encoder_tgt_complete_test.py with version 1.5 f/w. Here is the output:
Ver: 1.5
2.37 V
CHECKING ENCODER READINGS
258 0
Both motors moving Forward with LED On
after 5 sec 258 179
Both motors stopped with LED Off
None after stop cmd 258 186
None after 2 more sec 331 189
Both motors moving back with LED On
after 5 sec 516 364
None after stop cmd 524 371
None after 2 more sec 605 374
The left motor never stopped spinning so I had to interrupt the program and power the GoPiGo off.
The voltage reported 2.37V from this script. I knew this reading couldn’t be right, so I ran this simple script:
print “Voltage=%s”%volt()
print “F/W=%s”%fw_ver()
With version 1.3 f/w the output is:
Voltage=10.02
F/W=1.3
With version 1.5 f/w the output is:
Voltage=2.31
F/W=1.5
