Hi Iβve had a GrovePi for about 2 years, and seems not to work any more, example is it can not tell me what firmware is loaded, when complete_test.sh is run. The script stalls at that point.
Have you any suggestion, has it become useless?
Log below
Check space left
/dev/root 29G 3.7G 24G 14% /
devtmpfs 430M 0 430M 0% /dev
tmpfs 462M 0 462M 0% /dev/shm
tmpfs 462M 7.3M 455M 2% /run
tmpfs 462M 0 462M 0% /sys/fs/cgroup
tmpfs 6.0M 0 6.0M 0% /home/pi/WxRam
tmpfs 4.0M 0 4.0M 0% /home/pi/Logs
tmpfs 4.0M 480K 3.6M 12% /var/log
tmpfs 2.0M 0 2.0M 0% /home/pi/Archive
tmpfs 2.0M 0 2.0M 0% /var/log/nginx
/dev/mmcblk0p1 253M 49M 205M 20% /boot
tmpfs 93M 4.0K 93M 1% /run/user/1000
Check for dependencies
python 2.7.16-1 install ok installed
python-pip 18.1-5+rpt1 install ok installed
git 1:2.20.1-2+deb10u3 install ok installed
libi2c-dev 4.1-1 install ok installed
python-serial 3.4-4 install ok installed
python-rpi.gpio 0.7.0-0.1~bpo10+4 install ok installed
i2c-tools 4.1-1 install ok installed
python-smbus 4.1-1 install ok installed
scratch 1.4.0.6~dfsg1-6 install ok installed
I2C still in blacklist
SPI still in blacklist
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
RPI3 Pi 3 Model B v1.2
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Raspbian for Robots Version
Hostname
RASPI-1P-WEATHER-STATION
Checking for Atmega chip
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
Using Port : unknown
Using Programmer : gpio
gpio/direction: No such file or directory
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
NOTE: it is normal for this one to fail
Error: Could not open file /dev/i2c-0' or /dev/i2c/0β: No such file or directory
Checking I2C bus 1
00: β 04 β β β β β β β β β β β
10: β β β β β β β β β β β β β β β β
20: β β β β β β β β β β β β β β β β
30: β β β β β β β β β β β β β β β β
40: β β β β β β β β β β β β β β β β
50: β β β β β β β β β β β β β β β β
60: β β β β β β β β β β β β β β β β
70: β β β β β β β β
Checking for firmware version
Thanks Michael
