Running tests on Firmware Stuff in the grovepi documentation.
The question here is this.
dpkg-query: no packages found matching arduino
dpkg-query: no packages found matching minicom
find: ‘/ run / user / 1000 / gvfs’: Denial of permission
wiringPi Not Found (ERR)
I2C still in blacklist (ERR)
SPI still in blacklist (ERR)
I know in this section [wiringPi Not Found (ERR)] that my Raspberry Pi has no packages.
I did ‘pip install wiringPi’ but the same shooting log came out.
And I2C and SPI enabled through “sudo raspi-config” but the same shooting log came out.
Is the way I solved the right way?
Is this shooting log normal? Is there anything wrong with the other parts of the shooting log?
Please help me …
Check space left
/dev/root 7.0G 6.3G 409M 94% /
devtmpfs 370M 0 370M 0% /dev
tmpfs 374M 0 374M 0% /dev/shm
tmpfs 374M 5.1M 369M 2% /run
tmpfs 374M 0 374M 0% /sys/fs/cgroup
/dev/mmcblk0p1 253M 52M 201M 21% /boot
tmpfs 75M 4.0K 75M 1% /run/user/1000
Check for dependencies
python 2.7.16-1 install ok installed
python-pip 18.1-5+rpt1 install ok installed
git 1:2.20.1-2 install ok installed
libi2c-dev 4.1-1 install ok installed
python-serial 3.4-4 install ok installed
python-rpi.gpio 0.7.0~buster-1 install ok installed
i2c-tools 4.1-1 install ok installed
python-smbus 4.1-1 install ok installed
scratch 1.4.0.6~dfsg1-6 install ok installed
find: ‘/run/user/1000/gvfs’: 허가 거부
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.50
Copyright © 2012-2018 Gordon Henderson
Raspberry Pi Details:
- Device tree is enabled.
*–> Raspberry Pi 3 Model B Rev 1.2 - This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Raspbian for Robots Version
cat: /home/pi/di_update/Raspbian_For_Robots/Version: 그런 파일이나 디렉터리가 없습니다
Hostname
raspberrypi
Checking for Atmega chip
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0' or /dev/i2c/0’: No such file or directory
Checking I2C bus 1
70: – -- – -- – -- – --
Checking for firmware version
GrovePi has firmware version: 1.4.0
