I have both a GoPiGo and a GrovePi which I use together semi-frequently. I recently ordered some new sensors to use with them and found that the GoPiGo could no longer communicate with the GrovePi (with or without the new sensors attached). I disconnected the pair and connected just the GrovePi to my RPi and everyhting was fine. Iβm not sure why out of the blue the GrovePi doesnβt work with the GoPiGo anymore, its been connected the same way (through I2C) for months now, with no issue.
I ran the troubleshooting test on the GrovePi whilst it was connected to the GoPiGo and have copied the log file below:
Check space left
/dev/root 7.2G 2.9G 4.0G 42% /
devtmpfs 427M 0 427M 0% /dev
tmpfs 432M 0 432M 0% /dev/shm
tmpfs 432M 6.1M 425M 2% /run
/dev/mmcblk0p1 60M 21M 40M 35% /boot
tmpfs 87M 0 87M 0% /run/user/1000
Check for dependencies
python-rpi.gpio 0.6.2~jessie-1 install ok installed
arduino 2:1.0.5+dfsg2-4 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.32
Copyright Β© 2012-2015 Gordon Henderson
Raspberry Pi Details:
Type: Pi 2, Revision: 01, Memory: 1024MB, Maker: Embest
- Device tree is enabled.
- This Raspberry Pi supports user-level GPIO access.
-> ie. export WIRINGPI_GPIOMEM=1
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 004: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
|__ Port 3: Dev 4, If 0, Class=Vendor Specific Class, Driver=rtl8192cu, 480M
Raspbian for Robots Version
V 6.10
This version of Raspbian was modified by Dexter Industries on the Wheezy Raspbian Build.
This version was updated on 2016.10.05
Hostname
dex
Checking for Atmega chip
Copyright Β© 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright Β© 2007-2009 Joerg Wunsch
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0' or/dev/i2c/0β: No such file or directory
Checking I2C bus 1
00: β -- β -- β 08 β -- β -- β -- β
10: β -- β -- β -- β -- β -- β -- β -- β --
20: β -- β -- β -- β -- β -- β -- β -- β --
30: β -- β -- β -- β -- β -- β -- β -- β --
40: β -- β -- β -- β -- β -- β -- β -- β --
50: β -- β -- β -- β -- β -- β -- β -- β --
60: β -- β -- β -- β -- β -- β -- β -- β --
70: β -- β -- β -- β --
Checking for firmware version
File β/home/pi/Desktop/GrovePi/Software/Python/grove_firmware_version_check.pyβ, line 40, in
print(βGrovePi has firmware version: %sβ %grovepi.version())
File β/home/pi/Desktop/GrovePi/Software/Python/grovepi.pyβ, line 258, in version
return β%s.%s.%sβ % (number[1], number[2], number[3])
TypeError: βintβ object has no attribute βgetitemβ
