GoPiGo OS isn’t updated yet, no. It’s in the plans but hasn’t happened yet.
If you need either the Pi5 or the v3 camera, then you have to install the libraries on your own version of Raspberry Pi OS, and Bloxter isn’t available. Python is, though.
We need to be able to build GoPiGo O/S images ourselves. If “the powers that be” suddenly decide to depreciate the GoPiGo, we’d be stuck.
</beating a dead horse>
Using the “standard” curl installation path? (As in Trixie?)
If you’re going the curl route on Trixie, the system Python there is 3.13 (check with python3 --version before you start). Because Debian 13 enforces PEP 668, a straight pip install into system Python will refuse; create a venv and install the GoPiGo3 libraries inside it rather than reaching for --break-system-packages. On your image-building point: the OS is largely pi-gen plus the Dexter repos, so a community fork is plausible, though keeping the Bloxter side in sync is the harder part.
