LED Fade not working
Hi. Brand new user here. I have a problem with the led_fade program. It runs for several seconds and then stops with the following error:
  File "led_fade.py", line 52, in <module>
    grovepi.analogWrite(led,i//4)
  File "build/bdist.linux-armv7l/egg/grovepi.py", line 232, in analogWrite
  File "build/bdist.linux-armv7l/egg/grovepi.py", line 173, in write_i2c_block
  File "/usr/local/lib/python2.7/dist-packages/smbus_cffi-0.5.1-py2.7-linux-armv7l.egg/smbus/util.py", line 59, in validator
    return fn(*args, **kwdefaults)
  File "/usr/local/lib/python2.7/dist-packages/smbus_cffi-0.5.1-py2.7-linux-armv7l.egg/smbus/smbus.py", line 269, in write_i2c_block_data
    list_to_smbus_data(data, vals)
  File "/usr/local/lib/python2.7/dist-packages/smbus_cffi-0.5.1-py2.7-linux-armv7l.egg/smbus/smbus.py", line 303, in list_to_smbus_data
    data.block[i + 1] = val
OverflowError: integer 16383 does not fit 'unsigned char'
As I am a total NOOB, this is incomprehensible to me. I did update both the Pi and and Dexter.
Am I also incorrect in that there are several errors in the user manual?
Thanks, Steve
Hi @steve2q,
The script is actually badly written. This is what it should look like:
import time
import grovepi
# Connect the Rotary Angle Sensor to analog port A2
potentiometer = 2
# Connect the LED to digital port D5
led = 5
grovepi.pinMode(led,"OUTPUT")
time.sleep(1)
def translate(value, leftMin, leftMax, rightMin, rightMax):
    # Figure out how 'wide' each range is
    leftSpan = leftMax - leftMin
    rightSpan = rightMax - rightMin
    # Convert the left range into a 0-1 range (float)
    valueScaled = float(value - leftMin) / float(leftSpan)
    # Convert the 0-1 range into a value in the right range.
    return rightMin + (valueScaled * rightSpan)
    try:
        # Read resistance from Potentiometer
        sensor_value = grovepi.analogRead(potentiometer)
        voltage = sensor_value / 1023.0
        degrees = voltage * 300
        brightness = int(translate(degrees, 0, 300, 0, 255))
        print(brightness, sensor_value)
        # Send PWM signal to LED
        grovepi.analogWrite(led, brightness)
    except IOError:
        print("Error")
I haven’t tested it, so take it with a grain of salt. If this one I’ve given you works, I’m gonna replace it here: https://github.com/DexterInd/GrovePi/blob/master/Projects/LED_Fade/led_fade.py
Hi Robert. Thank you for getting back to me: I created a file called LED_Fade2.py and placed your code in it. When I ran the program, it immediately threw the following error(s):
pi@dexter:~/Desktop/GrovePi/Projects/LED_Fade2 $ sudo python LED_Fade2.py
(255.0, 1023)
File “LED_Fade2.py”, line 34, in
File “build/bdist.linux-armv7l/egg/grovepi.py”, line 232, in analogWrite
File “build/bdist.linux-armv7l/egg/grovepi.py”, line 173, in write_i2c_block
File “/usr/local/lib/python2.7/dist-packages/smbus_cffi-0.5.1-py2.7-linux-armv7l.egg/smbus/util.py”, line 59, in validator
File “/usr/local/lib/python2.7/dist-packages/smbus_cffi-0.5.1-py2.7-linux-armv7l.egg/smbus/smbus.py”, line 269, in write_i2c_block_data
File “/usr/local/lib/python2.7/dist-packages/smbus_cffi-0.5.1-py2.7-linux-armv7l.egg/smbus/smbus.py”, line 303, in list_to_smbus_data
TypeError: an integer is required
Steve
I have a follow up to my previous. Is there any chance that the GrovePi is trying to use GPIO pins 23 and/or 24? The reason I ask is I have a Mausberry shut-down switch which is hooked to and uses a startup script for those pins. I have attached the log file from the troubleshooting session I just ran.log.txt (7.0 KB)
Hi @steve2q,
I have updated the script I had written - please run it again and see if it works. The problem was the value that was being passed down to analogWrite function: it was a float instead of an integer.
And GPIO pins 23 and 24 are only used when the firmware is flashed to the GrovePi, so you should be okay.
Robert…I cant find the updated script…is it at [https://github.com/DexterInd/GrovePi/blob/master/Projects/LED_Fade/led_fade.py ?? If so, when I go there and look at it, it is the same as what I already have.
Thanks, Steve
The updated script is in this thread here, a few posts up here, not on the repo, not until it is confirmed it’s working for you.
Anyway, I’m copy-pasting it again here:
import time
import grovepi
potentiometer = 2
led = 5
time.sleep(1)
    try:
    except IOError:
        print("Error")
Let me know if it now works.
Hi Robert. I tried the new file, but it only works for a short time. Before the error, I can vary the output of the LED with the potentiometer. Here are the errors listed (slightly different then before):
(113, 455)
(113, 455)
(113, 455)
(16335, 65535)
  File "led_fade3.py", line 34, in <module>
OverflowError: integer 16335 does not fit 'unsigned char'
Still no luck. I have updated and upgraded the Pi, and updated the firmware on the GrovePi. I still cannot get LED_Fade to work, and am somewhat disappointed as this should be a very basic piece of software. So far the only thing that runs properly is blink. I have absolutely no ideas; maybe it is a hardware issue.
