Consistent with my goal to utilize as few sensors on my robot as possible by maximizing the capabilities of each sensor, I was wondering if it was possible to use the PiCamera to measure room light levels, similar to a Grove Light Sensor, or a photo-resistor that give a “unit-less” analog value.
It turns out the PiCamera tags every JPEG photo with a floating point “BrightnessValue” which rises logarithmically with increasing light levels. This is my project:
Log and Plot Brightness Value Using PiCamera
Project to monitor light level using picamera JPG format EXIF Brightness Value, and generate a plot versus local time for 24 hours from 00:00 to 24:00
The PiCamera pointed horizontal 10 inches off the floor, records a Brightness Value:
- exactly 0.0 for total darkness
- roughly 0.05 in a dark room with light streaming through the doorway from kitchen 30 feet away
- roughly 0.7 for a small room lit only by 150 watt overhead lighting
- roughly 1.0 for a small room with one large window at evening light plus overhead lighting
- roughly 1.5 for a small room with one large window during end of the world storm outside
- roughly 2.6 for a small room with one large window with partial blinds and full sun outside
Based on:
- Understanding Brightness Value: https://www.raspberrypi.org/forums/viewtopic.php?t=44784#p357111
- Python access to EXIF data of jpg files https://pypi.org/project/ExifRead/
- Plotting in Python: https://plot.ly/python/
- PiCamera https://picamera.readthedocs.io/en/release-1.13/recipes1.html#capturing-to-a-file
Example plot:
Code is at: https://github.com/slowrunner/Carl/tree/master/Projects/LogLightValueAndPlot
