Will the GoPiGo work with a Rev 1 board, including the servo and ultrasonic add on?
Ashley
Ashley
Hey Ashley,
It should! The GoPiGo uses I2C to send signals back and forth. If you look at the code in “gopigo.py” under /Software/Python there is a small hint on line 27.
That should be the only configuration issue you need to deal with. The python library currently auto configures for rev 2 and rev 3.
Let us know if you have any issues with this setup, we should be able to walk you through it.
