We’re trying to do Mission 8 and we can’t get Scratch to show ‘motion’ in the sensor value. We’ve updated the GoBox and we haven’t had any trouble attaching sensors in past missions. But, now, no matter how many times we’ve rebooted, turned off and rechecked the connections, turned back on, etc - we can’t get ‘motion’ to show up in the sensor value dropdown.
Any ideas?
I did run the troubleshooter and here’s what it gave me:
Check space left
/dev/root 7.2G 2.7G 4.2G 39% /
devtmpfs 427M 0 427M 0% /dev
tmpfs 432M 0 432M 0% /dev/shm
tmpfs 432M 6.1M 425M 2% /run
/dev/mmcblk0p1 60M 21M 40M 35% /boot
tmpfs 87M 4.0K 87M 1% /run/user/1000
a
Check for dependencies
python-rpi.gpio 0.6.2~jessie-1 install ok installed
arduino 2:1.6.0 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.32
Raspberry Pi Details:
Type: Pi 2, Revision: 01, Memory: 1024MB, Maker: Embest
- Device tree is enabled.
- This Raspberry Pi supports user-level GPIO access.
-> ie. export WIRINGPI_GPIOMEM=1
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 004: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
|__ Port 3: Dev 4, If 0, Class=Vendor Specific Class, Driver=rtl8192cu, 480M
Checking for Atmega chip
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0' or/dev/i2c/0’: No such file or directory
Checking I2C bus 1
00: – -- – -- – 08 – -- – -- – -- –
70: – -- – -- – -- – --
Checking for firmware version and CPU Speed and Voltage
v 1.6
CPU speed: 2
10.99 V
CHECKING ENCODER READINGS
0 0
Both motors moving Forward with LED On
after 5 sec 186 182
Both motors stopped with LED Off
None after stop cmd 194 188
None after 2 more sec 196 189
Both motors moving back with LED On
after 5 sec 384 378
None after stop cmd 392 384
None after 2 more sec 394 385
CHECKING ENCODER TARGETING
Initial encoder read vals: 0 2
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 0
Final encoder read vals: 74 74
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 0
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 0
Final encoder read vals: 77 74
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 0
Final encoder read vals: 76 74
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 1
Enc tgt Status: 0
Final encoder read vals: 75 74
