Multichannel gas sensor need help
I have problems with the Grove I2C multichannel gas sensor and I hope you can help me.
This sensor is on port 0x04, so not compatible with grovepi unless you load an alternate firmware
I don’t know where the alternate firmware is. Can you guide me? If it works, I will update the tutorial to our wiki.
Best Regards,
Seeed Technical Support Zeng
Hi @xudong.zeng,
You might be interested in changing the GrovePi’s I2C address by following the following tutorial:
Even though that article is actually meant for stacking multiple GrovePis, I think you could get away with it for this particular issue.
Just so you know, here’s the folder that’s being referenced in that article:
