My gopigo robot doesn’t produce a WiFi signal even when the wifi green light is on. Any help is appreciated?
I am going to guess you loaded up the latest GoPiGo OS version 3.0.3 and since you are seeing the WiFi LED has turned Green, your GoPiGo3 is broadcasting a WiFi signal.
This LED is green, correct?
What device are you using to connect to the robot?
It should have a “WiFi Settings” screen that looks something like:
or similar to this:
If you are not seeing the GoPiGo listed, you can try turning WiFi on the device (your pad/laptop/desktop) off and then back on.
After you click on the GoPiGo network, your device will connect to your robot and the WiFi LED should turn blue.
Can you describe what you have tried and what you saw on your device? (screenshot if possible)
Is this the guide you are following?
Agree.
We need to know much more to help you:
- What version/type of Raspberry Pi?
- What version of the GoPiGo? (Red/green?)
- Which operating system are you using?
- Have you tried any troubleshooting steps yourself?
This will help us help you.
