New BrickPi3 Test or any python program fail
Hi
I just bought a brickpi3 with the box for my raspberry pi 3 with rasbian OS. I connected the hardware together, downloaded the python BrickPi3.py from the github as instructed, performed the install, and then when I try to run the all_test.sh or any py file, and they fail on the same line
File “LED.py”, line 18, in
import brickpi3 # import the BrickPi3 drivers
File “build/bdist.linux-armv7l/egg/brickpi3.py”, line 20, in
IOError: [Errno 2] No such file or directory
so the initialization fails on the spi open(0,1).
the boot/config.txt has the dtparam sets to spi.
I could not find working solution in the forum.
Regards
I’m not quite sure of the cause. Can I suggest using raspbian for robots? It should work with your brickpi3 out of the box. Have you tried running the setup file in BrickPi3/Software/Python/ ?
https://www.dexterindustries.com/howto/install-raspbian-for-robots-image-on-an-sd-card/
Hi @jerome.boyer,
Can you navigate to your BrickPi3/Software/Python folder and run this command sudo python setup.py install, this should fix your issue.
-Shoban
Hi
Thank you for the answers: so sudo python setup.py install did not make it. Installing the Raspbian for Robots helped and now it is working. I also upgraded Raspbian version and it seems to continue working.
I also manage to understand it is important to power the BrickPi3 with 10V and not the Raspberry PI which does not deliver enough power to the BrickPi3.
Now the fun starts…
Hi @jerome.boyer,
Glad that you have your BrickPi3 working. Enjoy your BrickPi3.
-Shoban
