I am not sure what I am doing wrong here. I set the gopigo2 with Raspberry Pi 3. As per instructions, wifi works but I am unable to run the motor in demo mode. All I see that it ran the test. I do not see any indicators changing lights as per terminal statements but the motors do not turn. Here is the log,txt details Any advice?
Check space left
/dev/root 15G 3.0G 11G 22% /
devtmpfs 426M 0 426M 0% /dev
tmpfs 430M 0 430M 0% /dev/shm
tmpfs 430M 6.1M 424M 2% /run
tmpfs 430M 0 430M 0% /sys/fs/cgroup
/dev/mmcblk0p1 63M 21M 42M 34% /boot
tmpfs 86M 0 86M 0% /run/user/1000
Check for dependencies
arduino 2:1.6.0 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.36
Raspberry Pi Details:
Type: Pi 3, Revision: 02, Memory: 1024MB, Maker: Embest
- Device tree is enabled.
*–> Raspberry Pi 3 Model B Rev 1.2 - This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
|__ Port 5: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 5: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 5: Dev 4, If 2, Class=Human Interface Device, Driver=usbhid, 12M
Checking for Atmega chip
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0' or/dev/i2c/0’: No such file or directory
Checking I2C bus 1
70: – -- – -- – -- – --
Checking for firmware version and CPU Speed and Voltage
v -1
CPU speed: -1
-1 V
CHECKING ENCODER READINGS
-1 -1
Both motors moving Forward with LED On
after 5 sec -1 -1
Both motors stopped with LED Off
-1 after stop cmd -1 -1
-1 after 2 more sec -1 -1
Both motors moving back with LED On
after 5 sec -1 -1
CHECKING ENCODER TARGETING
Initial encoder read vals: -1 -1
File “/home/pi/Dexter/GoPiGo/Software/Python/tests/enc_tgt_test.py”, line 69, in
enc_stat=read_enc_status()
File “build/bdist.linux-armv7l/egg/gopigo.py”, line 610, in read_enc_status
File “build/bdist.linux-armv7l/egg/gopigo.py”, line 601, in read_status
IOError: [Errno 121] Remote I/O error
