Can you please explain what the setup.py script does?
My understanding is that it copies the grovepi.py script into a library that is accessible to all python scripts using an import grovepi. Does that sound right?
Does that mean we need to run the setup.py script again each time we get the latest changes from your git repo, where the grovepi.py file has changed?
Hi mcauser,
You are completely right, the script creates and installs the GrovePi library so that it’s accessible from the Python interpreter and you would have to run it again if you have made any changes to the library and want that to be accessible from Python too.
Hello, i’ve got the same problem but i don’t know what to do. I wrote the setup.py fiel in /usr/lib/python2.7 and run “sudo python setup.py install” All seems fine but when i run the command “import grovepi” i got the error message “ImportError : No modle named grovepi”
Hi I have a similar problem but mine is more of the issue no module named: Twitter. I have tried the python setup.py install but the issue still exist.
You can use pip install twitter to install the twitter library for Python. You can refer to the documentation here: https://pypi.python.org/pypi/twitter .
