I followed the steps here: https://www.dexterindustries.com/Arduberry/getting-started/
and I don’t see raspberry pi gpio programmer listed. Please help, I need this urgently
ok, that was due to arm architecture I use… Ichanged it in the setup script and got it installed.
Now however I get AVR degice not responding
initialization failed, rc=-1
the first time i tried upload it complained about something 0x0c!=0x00. now i get the error above…
if I run acrdude:
avrdude -c gpio -p m328p
this check.
This may take a few minutes, please be patient
Press Enter to start…
Check for dependencies
Checking Serial for BrickPi
Checking Hardware revision
Read pins
Check I2C
Check the /dev folder
Check BrickPiStatus
python: can’t open file ‘ser.py’: [Errno 2] No such file or directory
please help, at the moment I have ardubrick
sudo avrdude -c gpio -p m328p -F
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
troubleshoot script output:
python 2.7.3-4+deb7u1 install ok installed
python-pip 1.1-3 install ok installed
git 1:1.7.10.4-1+wheezy1 install ok installed
libi2c-dev 3.1.0-2 install ok installed
python-serial 2.5-2.1 install ok installed
python-rpi.gpio 0.3.1a-1 install ok installed
i2c-tools 3.1.0-2 install ok installed
python-smbus 3.1.0-2 install ok installed
arduino 1:1.0.1+dfsg-7 install ok installed
minicom 2.6.1-1 install ok installed
scratch 1.4.20130509-1 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Clock speed not Configured(ERR)
Serial Port Enabled
Serial Port Login Already Disabled
gpio version: 2.21
Copyright © 2012-2014 Gordon Henderson
Raspberry Pi Details:
Type: Model B, Revision: 2, Memory: 512MB, Maker: Sony
±----±----±--------±-----±–±Model B2-±–±-----±--------±----±----+
| BCM | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | BCM |
| | | 3.3v | | | 1 || 2 | | | 5v | | |
| 2 | 8 | SDA.1 | ALT0 | 1 | 3 || 4 | | | 5V | | |
| 3 | 9 | SCL.1 | ALT0 | 1 | 5 || 6 | | | 0v | | |
| 4 | 7 | GPIO. 7 | IN | 1 | 7 || 8 | 1 | ALT0 | TxD | 15 | 14 |
| | | 0v | | | 9 || 10 | 1 | ALT0 | RxD | 16 | 15 |
| 17 | 0 | GPIO. 0 | IN | 0 | 11 || 12 | 0 | IN | GPIO. 1 | 1 | 18 |
| 27 | 2 | GPIO. 2 | IN | 0 | 13 || 14 | | | 0v | | |
| 22 | 3 | GPIO. 3 | IN | 0 | 15 || 16 | 0 | IN | GPIO. 4 | 4 | 23 |
| | | 3.3v | | | 17 || 18 | 0 | IN | GPIO. 5 | 5 | 24 |
| 10 | 12 | MOSI | ALT0 | 1 | 19 || 20 | | | 0v | | |
| 9 | 13 | MISO | ALT0 | 1 | 21 || 22 | 0 | IN | GPIO. 6 | 6 | 25 |
| 11 | 14 | SCLK | ALT0 | 0 | 23 || 24 | 1 | ALT0 | CE0 | 10 | 8 |
| | | 0v | | | 25 || 26 | 1 | ALT0 | CE1 | 11 | 7 |
| 28 | 17 | GPIO.17 | IN | 0 | 51 || 52 | 0 | IN | GPIO.18 | 18 | 29 |
| 30 | 19 | GPIO.19 | IN | 0 | 53 || 54 | 0 | IN | GPIO.20 | 20 | 31 |
70: – -- – -- – -- – --
i2c-0
i2c-1
spidev0.0
spidev0.1
ttyAMA0
BrickPi Found
Arduberry Found
grovePi Found
GoPiGo Found
-2
BrickPi Not Found (ERR)
Tried with dexter distro… same result… avrdude: Device signature = 0x000000
Seems I just bought myself a brick
A local stora has Atmega chips on stock… but I don’t have a programmer… how can I flash it to try another chip?
Ok, it seems you don’t use bootloader… that’s actually cool… so arduberry is atmega programmer?? I’ll try this tomorrow: http://www.dexterindustries.com/forum/?topic=repairing-a-broken-arduberry
You owe me one guys. Hope it works, I need my robot by Friday!
Hi zapp0,
It indeed looks like you have a broken Arduberry. Can you just check if all the connections are soldered properly and check if the ATmega 328 is connected properly (the notch indicating the pin 1 should be facing the side away from the Raspberry Pi connector). Can you also post some good pics of the Arduberry from both the top and bottom side so that we can try to find if anything is wrong.
If you would like it to be replaced, you can get in touch with us at http://www.dexterindustries.com/site/?page_id=65 . But I don’t think that you’ll be able to get it by friday. The fastest way to get it working would be to get a spare Atmega chip and try using it.
Arduberry indeed does not use the bootloader and we use the Raspberry Pi SPI pins to directly program it, so you don’t need to have a programmer.
Sorry for all the troubles.
