I bought recently GoPiGo and have assembled it (btw. it is not easy to find assembly documentation on the page, I’ve found the link in google).
It works however not as I expected, the left wheel rotates slower than the right one
it is especially visible at lower speeds (at some speed one of the wheels is already rotating while the other one just “makes sounds”)
I thought one of the motors I’ve got is broken, but when I measured voltage on the motors pins they are different for both motors, in both cases when the motors are connected and disconnected
What seems to be suspicious:
- I had to connect motor wires not like in “assembly picture” White-Black-White-Black, but Black-White-White-Black (otherwise they rotate in opposite directions when “move forward”)
- when trying to read from I2C (e.g. state of voltage or status or LED switch) I receive exceptions (I work with Java libraries: Error reading from /dev/i2c-1 at address 0x8 to address 0x1. Got -1)
- the LEDs switch On/Off does not work (usually one of the LEDs is always ON, the other is OFF)
- when I used Forward with PID - one of the wheels tries noticeably adjust the speed but it is not smooth (slowing down and accelerating all the time)
