Not entirely sure if this is a Pi4 issue but I have installed the grovepi+ all manner of other pi’s without issue and this is the first p4.
I am running Buster which is updated to the latest dist-upgrade.
I have tried installing the grovepi using the easy script and the detailed with the same outcome.
The only error i get is:
Running smbus-cffi-0.5.1/setup.py -q bdist_egg --dist-dir /tmp/easy_install-9Nz54T/smbus-cffi-0.5.1/egg-dist-tmp-aBZOxb
: internal compiler error: in peep2_find_free_register, at recog.c:3160
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-8/README.Bugs> for instructions.
No working compiler found, or bogus compiler options passed to
the compiler from Python's standard "distutils" module. See
the error messages above. Likely, the problem is not related
to CFFI but generic to the setup.py of any Python package that
tries to compile C code. (Hints: on OS/X 10.8, for errors about
-mno-fused-madd see http://stackoverflow.com/questions/22313407/
Otherwise, see https://wiki.python.org/moin/CompLangPython or
the IRC channel #python on irc.freenode.net.)
Trying to continue anyway. If you are trying to install CFFI from
a build done in a different context, you can ignore this warning.
error: Setup script exited with error: command ‘arm-linux-gnueabihf-gcc’ failed with exit status 1
I have hunted google for:
- : internal compiler error: in peep2_find_free_register, at recog.c:3160
- error: Setup script exited with error: command ‘arm-linux-gnueabihf-gcc’ failed with exit status 1
- Running smbus-cffi-0.5.1/setup.py -q bdist_egg --dist-dir /tmp/easy_install-9Nz54T/smbus-cffi-0.5.1/egg-dist-tmp-aBZOxb
none of which has turned up much outside of installed python-dev and other build-essentials all which I have tried including reboots without change.
Any help would be greatly appreciated.
