Hi, I’m sharing these in the hope they help someone, and that DI might fix up their installation and instructions.
I’m installing my GrovePi on my Pi2 running Raspbian. I followed the instructions here http://www.dexterindustries.com/GrovePi/get-started-with-the-grovepi/setting-software/
After install I tried the i2cdetect test and got nothing, same with the blink test. digging in the forums turned up the missing steps.
- you need to : sudo apt-get install python-smbus
[note this seems to include 12c-tools] - you need to run: sudo raspi-config
advanced->A7>Yes to enable i2c, then reboot.
After doing this i2cdetect now runs and shows 04.
Now trying to run grove_led_blink.py test (BTW your instructions need updating with the new script name) gives me a runtime error: “This module can only be run on a Raspberry Pi!”
The version of RPi.GPIO needs to be updated to work with a Pi2 - details here https://github.com/metachris/RPIO/issues/53
Steps to resolve provided by user neterlbcn:
Uninstall the version that dpkg/apt-get knows about.
sudo apt-get purge python{,3}-rpi.gpio -
Scan your filesystem for all copies of RPi.GPIO
find /usr -name "RPi"
remove everything that you find -
sudo apt-get install python{,3}-rpi.gpio
to put back a good version.
I now have a blinking LED!
Cheers
netgio
