at about the 7:50 mark, he states that he can test the GoPiGo running the motors if he uses a 2 amp power supply ( instead of the typical 1 amp that comes with the Raspberry pi Model B+ ).
Even though a 2A power supply might be able to power everything, it is highly recommended to keep a battery pack attached if you are going to try running the motors. The motors pull a lot of current and the voltage on the Pi might become unstable and it might cause the Pi to restarts.
