Thanks so much for sorting this out for us, guys! Kudos! I will be posting a video once I find the spare time to play with this robot a little more.
One little thing - one of the LEDs still does not light up. It’s a really minor issue though as the motor on that side now works and that’s all I really care about.
Can you doublecheck that both the encoders are connected properly.
If they are correctly connected, can you try running Software/Python/basic_test_all.py and give w as a command to move forward, x to stop. If the GoPiGo still keeps going round, can you try giving i as a command.
I’m having an issue with the power test after assembly. I’ve assembled the GoPiGo and attaching the battery leads gives no yellow LED or any sign of response. I’m able to attach the Raspberry Pi, power it and the controller with the RPi’s USB power input, update the firmware, and it tells me a GoPiGo is present and I get a green LED on the GoPiGo controller board. I’ve tried two sets of rechargeable batteries and a set of new Alkalines, but still no sign of life.
Is there something obvious I’m doing wrong?
Can you check with a multimeter to make sure that the battery pack gives a voltage of higher than 9V.
Also, double check the polarity of the connections that you are making for the connections to the GoPiGo board and don’t forget to turn on the GoPiGo power switch.
If it still does not work, can you upload some pictures of the battery pack and the connections with the GoPiGo.
