Hi, I am now using Temperature and Humidity Sensor for Intel Edison. And I use python to programming.
From the sample code, I found I should code as
from grovepi import *
dht_sensor_port = 7 # Connect the DHt sensor to port 7
try:
[ temp,hum ] = dht(dht_sensor_port,1)
But the intel edison tells me “AttributeError: ‘module’ object has no attribute ‘dht’”. I have install the library on my Inter Edison by "pip install grovepi"
I also tried to import grovepi, and use help(grovepi) to get the methods in the library, but it seems that the library only has one method “initialize()”. Could any tell me how can I get temperature and humidity data by Temperature and Humidity on Inter Edison using python?
Appreciate for the help!
