Problems with my GrovePi was due to firmware
Just an FYI if anyone is having trouble with their GrovePi+ giving incorrect information from sensors, check the firmware.
I was trying to use the ultrasonic sensor and getting all sorts of incorrect values. I was also experiencing delays and, oddly, the curosr was resetting to the bottom right corner.
Checking the firmware of the GrovePi+ returned “firmware version 156.46.28”
The real firmware was supposed to be 1.4.0.
To check the firmware: GrovePi/Software/Python/grove_firmware_version_check.py
to update the firmware https://www.dexterindustries.com/GrovePi/get-started-with-the-grovepi/updating-firmware/
After updating all of my data from the ultrasonic ranger sensor is working properly.
Interested in how much reading to reading variation you are seeing?
How accurate?
How long does a single measurement take?
I saw someone mention overheating of the US sensor. Yours is doing ok?
It seems very accurate. I have set the sleep time to 0.5 instead of 0.1.
I believe, as mentioned on my twitter conversation that the non-grove sensors had the overheating problem. The grove ultrasonic ranger is designed to alleviate that issue.
Only problem I have had is if the rPi goes to sleep while a program for the sensor is running, the sensor does not wake up when the rPi does. As the intended use will have audio playing throughout, I doubt if it will fall asleep.
