I’ve found that when I use “Advanced Bloxter” and create functions I hit an error when I try to execute the program. The error is:
local variable 'gpg' referenced before assignment
When I look at the Python code produced by Bloxter, the problem is quite clear. The gpg = easy.EasyGoPiGo3() line is written after my function is declared.
Is this a known problem? Is there a work-around I can employ?
The full python code is shown below:
import easygopigo3 as easy
import time
direction = None
x = None
my_servo_portSERVO1 = gpg.init_servo('SERVO1')
my_Distance_portI2C = gpg.init_distance_sensor('I2C')
time.sleep(0.1)
"""Describe this function...
def look_and_drive(direction):
global x
my_servo_portSERVO1.rotate_servo(direction)
if my_Distance_portI2C.read() > 15:
gpg.led_off(1)
gpg.led_off(0)
gpg.open_eyes()
if my_Distance_portI2C.read() > 30:
gpg.set_speed(400)
else:
gpg.set_speed(200)
gpg.forward()
else:
gpg.close_eyes()
gpg.set_speed(200)
if direction == 90:
gpg.led_on(1)
gpg.led_on(0)
gpg.turn_degrees(1*180, blocking=True)
else:
if direction == 45:
gpg.led_on(0)
gpg.turn_degrees(-1*45, blocking=True)
else:
gpg.led_on(1)
gpg.turn_degrees(1*45, blocking=True)
gpg.led_off(1)
gpg.led_off(0)
# start
direction = 45
direction = 90
direction = 135
time.sleep(0.05) # slowdown
