Python grovepi not working
I’m trying to setup grovepi on a recently formatted SD card on a Raspberry Pi 3B+, but after running the setup as instructed and running the all_tests.sh script under the Troubleshooting folder I don’t get the grovepi version printed as the log states (as follows), the module is also not found when I try to install a capacitive moisture sensor, for example:
Check space left
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        12G  3.6G  7.5G  33% /
devtmpfs        430M     0  430M   0% /dev
tmpfs           463M     0  463M   0% /dev/shm
tmpfs           463M  6.3M  456M   2% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           463M     0  463M   0% /sys/fs/cgroup
/dev/mmcblk0p6  253M   48M  205M  19% /boot
tmpfs            93M  4.0K   93M   1% /run/user/1000
Check for dependencies
python 2.7.16-1 install ok installed
python-pip 18.1-5+rpt1 install ok installed
git 1:2.20.1-2+deb10u3 install ok installed
libi2c-dev 4.1-1 install ok installed
python-serial 3.4-4 install ok installed
python-rpi.gpio 0.7.0-0.1~bpo10+4 install ok installed
i2c-tools 4.1-1 install ok installed
python-smbus 4.1-1 install ok installed
scratch 1.4.0.6~dfsg1-6 install ok installed
I2C still in blacklist
SPI still in blacklist
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
RPI3 Pi 3 Model B v1.2
Check the /dev folder
i2c-1
ttyAMA0
USB device status
Bus 001 Device 005: ID 046d:c077 Logitech, Inc. M105 Optical Mouse
Bus 001 Device 004: ID 05ac:0267 Apple, Inc. Magic Keyboard A1644
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
        |__ Port 2: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 2: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 2: Dev 4, If 2, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 3: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
Raspbian for Robots Version
Hostname
raspberrypi
Checking I2C bus for devices
Checking I2C bus 0
NOTE: it is normal for this one to fail
Checking I2C bus 1
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Checking for firmware version
Try turning on i2c and SPI in raspi-config and see if that helps.
Don’t forget to come back here and tell us what happened.
Thanks for the fast response.
I enabled them but it seems like the outcome is mostly the same:
Check space left
/dev/root        12G  3.7G  7.5G  33% /
tmpfs           463M   41M  422M   9% /dev/shm
tmpfs           463M  6.4M  456M   2% /run
Hardware revision
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Hostname
raspberrypi
Checking I2C bus 0
Checking I2C bus 1
I noticed that the log contains a I2C still in blacklist so I tried to follow this tutorial, but it didn’t help.
Did you try sudo i2cdetect -y 1?
What did you get?
The following
Looks like this one is beyond me - you’ve tried everything I would have tried.
I’m going to invite @cleoqc to join us, maybe she can help.
You should also send an email support@modrobotics.com. Describe the problem, what we’ve done, and ask them how to enable i2c.
Mention that i2c is blacklisted and we cannot get it working.
If they reply by e-mail, please post the answer here so others can benefit from this.
