Hi I have ordered the Raspberry Pi 2 B+ and an Arduberry (either not received yet). I have tried to download the raspberry pi sd image from the github website https://github.com/DexterInd/ArduBerry. but I get this “Sorry, the file you have requested does not exist.” they say this “Our custom image for the Raspberry Pi makes using the Arduberry easy. We’ve modified wheezy a little bit. You can download the latest image here:https://docs.google.com/file/d/0B0WChwP4CnLBMVNKajMydy1VcVU/edit?usp=sharing” Can I just use the ordinary Raspbian or due I need this special modified wheezy to make the Arduberry work with the RBP?
Raspberry pi 2B+
You can use your own image too, but you’ll have to run this configuration script to make it work: https://github.com/DexterInd/ArduBerry/blob/master/script/install.sh. This installs all the files necessary to use the Arduberry.
Let us know if you face any problems.
OK can you direct me to where I can find the image for the SD card? I will try to run the script above but I am sure that I will run into problems. I am fairly new at this.
OK I think I get it this script will run automatically if I go through your getting started sequence?
The script should automatically set things up. If that does not work out download and try the SD card from here: http://sourceforge.net/projects/dexterindustriesraspbianflavor/ .
Do let us know how it goes.
