What GPIO pins, if any, pass through the Arduberry?
I’d like to add a switch to a GPIO pin on the RPi and I’m not sure which ones are used by the Arduberry and which aren’t.
Hey Anti.Team,
All 26 pins pass through the Arduberry. I’ve attached a diagram of the pins that are used by the Arduberry.
Thanks! So just to make sure I’m reading this right, the pins with the flags are used by the Arduberry, and those that have no flags are not used at all? So I could use pins 9 (GND) and 11 (GPIO17) without any worries about interfering with the Arduberry functions (operation and programming), right?
Yes, you should be able to use Pin 9 and pin 11 without any problems.
