Does anyone know if the current version of Raspbian for Robots and the GrovePi are compatible with the new Raspberry Pi 4? Thanks!
Raspbian for Robots has not yet been updated to Buster, so it will not boot on the RPi4. The GrovePi is not yet fully tested on Buster and the RPi4.
The Dexter Industries software and hardware is planned to run on Buster with support for the RPi4, but we donât have a scheduled timeline.
Gotcha. Glad to hear itâs on the roadmap. GrovePi is amazing and with Buster-Raspbian and Pi4 support, it will be even better. Thanks!
Hello @Matt, would you have any news on the schedule for RPI4? Bought two RPI4 and GrovePi+ for my son and I to get projects started and now face a bit of a disappointmentâŚ
Weâre >this< close! It was all ready and then we found a snag in QA.
Hi. Would you have any news for us on the RPI4 compatibility? Hope that the ownership change is not negatively impacting the development. Thanks
It did slow us down a little bit, but weâre still on it. The GoPiGo3 can now be used with the Pi4 (although itâs not released as all robot support will be released at the same time). GrovePi is next.
Thank you for your patience.
Hi
Are there any news regarding grovepi for rpi4?
Asaf
Is there any tentative release date for GrovePi support for RPI4?
It doesnât seem like anybody from Dexter Industries is monitoring this forum.
To serve the educational market even better, weâve merged with Modular Robotics. Weâre now moving customer support from this forum to Zendesk. You can open a request for support through this webpage:
https://www.dexterindustries.com/contact/
Or by emailing support@dexterindustries.com
Text above was copied from this post:
https://forum.dexterindustries.com/t/dexter-industries-and-modular-robotics-are-merging/6929
-Kevin
oh Iâm still here, but busy.
Current status: brickPi is giving us trouble. We will release Rasbian for Robots when all robots can be supported.
Thank you
Glad to see youâre still here
Seemed quiet here since you announced the company merger. I understand youâre busy.
-Kevin
This is increasingly frustrating. Is there any chance of getting this resolved before Christmas time?
I found on the sourceforge page the experimental version for raspian buster which boots on a rpi 4
Here you can find it @marcus.stemberger
It can detect my grove pi, it detects firmware 1.4 but since Iâam new to this all Iâam unable to successfully check if the RFID module is working or not.
Maybe this will help other people for now
Indeed the experimental version is on Sourceforge. Shhh, itâs not official yet but itâs there
Thanks for the news!!!
I installed it today on my RPI4 (fresh âBusterâ) by using the âcurl -kL dexterindustries.com/update_grovepi | bashâ command. Then I rebooted and upgraded the firmware as well.
But somehow I cannot get anything to work at all. The green LED on the board is on all the time. Once I installed the GrovePi software though, I do get the error at the RPI start-up (see attached picture).
The log below was generated by the software. What am I missing?
Check space left
/dev/root 59G 6.1G 50G 11% /
devtmpfs 1.8G 0 1.8G 0% /dev
tmpfs 2.0G 0 2.0G 0% /dev/shm
tmpfs 2.0G 8.7M 1.9G 1% /run
tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
/dev/mmcblk0p1 253M 52M 201M 21% /boot
tmpfs 391M 4.0K 391M 1% /run/user/1000
Check for dependencies
python 2.7.16-1 install ok installed
python-pip 18.1-5+rpt1 install ok installed
git 1:2.20.1-2+deb10u1 install ok installed
libi2c-dev 4.1-1 install ok installed
python-serial 3.4-4 install ok installed
python-rpi.gpio 0.7.0~buster-1 install ok installed
i2c-tools 4.1-1 install ok installed
python-smbus 4.1-1 install ok installed
dpkg-query: no packages found matching arduino
dpkg-query: no packages found matching minicom
scratch 1.4.0.6~dfsg1-6 install ok installed
find: â/run/user/1000/gvfsâ: Permission denied
wiringPi Not Found (ERR)
I2C still in blacklist (ERR)
SPI still in blacklist (ERR)
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.50
Copyright (c) 2012-2018 Gordon Henderson
Raspberry Pi Details:
Type: Unknown17, Revision: 01, Memory: 0MB, Maker: Sony
* Device tree is enabled.
*--> Raspberry Pi 4 Model B Rev 1.1
* This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 008: ID 0b0e:0420 GN Netcom Jabra SPEAK 510
Bus 001 Device 007: ID 03f0:354a HP, Inc
Bus 001 Device 006: ID 046d:0843 Logitech, Inc. Webcam C930e
Bus 001 Device 005: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 003: ID 0bda:5411 Realtek Semiconductor Corp.
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 4: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 4, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 1: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 1: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 4: Dev 5, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 6, If 1, Class=Video, Driver=uvcvideo, 480M
|__ Port 1: Dev 6, If 2, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 1: Dev 6, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 1: Dev 6, If 3, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 2: Dev 7, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 2: Dev 7, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 8, If 0, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 3: Dev 8, If 1, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 3: Dev 8, If 2, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 3: Dev 8, If 3, Class=Human Interface Device, Driver=usbhid, 12M
Raspbian for Robots Version
Hostname
MarcBerry01
Checking for Atmega chip
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
User configuration file is "/home/pi/.avrduderc"
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Checking I2C bus 1
00: -- 04 -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Checking for firmware version
GrovePi has firmware version: 1.4.0
