Does the GoPiGo have the ability to read the voltage from the battery? Would be nice to be able to see when the voltage drops to a certain level, you could kick off a script to shut it down before it dies.
The GoPiGo indeed has an ability to check the voltage levels. You can use a command on the terminal “gpg” if you are using the Dexter Industries image. Also there’s a function in the GoPiGo python library called volt() which would give you the voltage back. You can try that out in the basic_test_all.py example program.
