Reading Muliple Sensors
I have been developing a weather station using a Grove Pi.
My question is regarding reading multiple sensors, can the GrovePi handle reading sensors one after another with out a timing gap.
Like example
digitalWrite(red_led, 1)
grovepi.digitalRead(5)
digitalWrite(red_led, 0)
grovepi.analogRead(16)
or should I add a timing gap like time.sleep(0.02) between reads
The code is being used to measure an anomometer rotations
Regard Michael
Hi @whimickrh,
I’d say you should add some delays between each call to the GrovePi. At least until we have a fix for the GrovePi - which by the way, we are working on making it more robust and reliable.
Thanks for your reply,
Can you suggest a delay, and I look forward to the fix
Let’s do it gradually starting with 5ms and then adding 10 ms on each increment.
