You are getting that error because the SPI-dev library is not found. It is not a critical error and since none of the devices use SPI, it should not be a problem.
I’m having this problem as well. I’ve removed all references to the device spi (i.e. deleted lines with dtparam=spi=on) in my config.txt but it still won’t boot with the same error. I’m running Noobs 1.3.9
