Hi Karan
Thanks for your prompt attention. Sorry for the late reply. Attached is a photo of the configuration I have. I have also tried different digital port. All work with the Grove LED, but only light up the led on the Grove Relay. The sig pin is always below 2V. The program I am using is a Windows IoT Core Application using the GrovePi api and a single line for turn the relay on.
DeviceFactory.Build.GrovePi().DigitalWrite(Pin.DigitalPin3),1);
The log from the test is as follow
Check space left
/dev/root 3.6G 2.7G 724M 79% /
devtmpfs 427M 0 427M 0% /dev
tmpfs 432M 0 432M 0% /dev/shm
tmpfs 432M 6.1M 425M 2% /run
/dev/mmcblk0p1 60M 21M 40M 35% /boot
tmpfs 87M 4.0K 87M 1% /run/user/1000
Check for dependencies
python-rpi.gpio 0.6.2~jessie-1 install ok installed
arduino 2:1.0.5+dfsg2-4 install ok installed
wiringPi Found
wiringPi Found
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.32
Raspberry Pi Details:
Type: Pi 2, Revision: 01, Memory: 1024MB, Maker: Embest
- Device tree is enabled.
- This Raspberry Pi supports user-level GPIO access.
-> ie. export WIRINGPI_GPIOMEM=1
Check the /dev folder
i2c-1
spidev0.0
spidev0.1
ttyAMA0
USB device status
Bus 001 Device 004: ID 045e:07b2 Microsoft Corp.
|__ Port 5: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 5: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 5: Dev 4, If 2, Class=Human Interface Device, Driver=usbhid, 12M
Raspbian for Robots Version
V 6.9
This version of Raspbian was modified by Dexter Industries on the Jessie Raspbian Build.
This version was updated on 2016.03.20
Hostname
dex
Checking for Atmega chip
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0’ or/dev/i2c/0’: No such file or directory
Checking I2C bus 1
70: – -- – -- – -- – --
Checking for firmware version
GrovePi has firmware version: 255.255.255
