I got an error installing the library grovepi and now every command written in command line returns dpgk was interrupted.
What’s the command to remove the library thanks.
Erazin ,
This is an interesting issue.
So first you can’t remove the library without using the command line. So I think that option is out. In fact you can’t do much without the command line on Linux.
However there is way to fix it. I found on StackOverflow how to fix it.
First run sudo dpkg --configure -a
If it still isn’t working run sudo apt install -f
Then re run the first command.
If it doesn’t work I suggest using Raspbian for robots! It will have the grovepi library preinstalled.
https://www.dexterindustries.com/howto/install-raspbian-for-robots-image-on-an-sd-card/
If you don’t want to install Raspbian for robots we can and hopefully others can try to get it working.
