We have started with a training/course and all got a Pi B3+ with the GrovePi starter kit.
Running with Raspbian and we alle seem to get an Error 121 when running the LCD scripts.
i2cdetect -y 1 gives us different outputs on the last line. Sometimes none, sometimes 70, someties 74 and 75.
Any help on this?
Hi @tijmenschoemaker,
Can you tell us what LCD scripts you are running, precisely?
And at the same time, tell us what devices/sensors you have connected to the GrovePi or to the Raspberry Pi for that matter?
We were running with temp + hum sensor, 2 leds and running the standard python grove_rgb_lcd scripts.
-edit-
Just turned on my pi again.
i2cdetect -y 1 before execution of script:
root@pi-tijmen:/home/pi/Dexter/GrovePi/Software/Python# i2cdetect -y 1
00: 03 -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- 38 -- -- -- -- -- 3e --
40: -- -- -- -- -- 45 46 -- -- -- -- -- -- -- -- --
60: -- -- 62 -- -- -- -- -- -- -- -- -- -- -- -- --
70: 70 -- -- -- -- -- -- --
40: -- 41 42 -- 44 45 -- -- -- -- -- -- -- -- -- --
This time, with just the 7" LCD, GrovePi board en the RGB_LCD. Ran the example.py from the software folder:
root@pi-tijmen:/home/pi/Dexter/GrovePi/Software/Python/grove_rgb_lcd# python example.py
File "example.py", line 43, in <module>
setRGB(c,255-c,0)
File "/home/pi/Dexter/GrovePi/Software/Python/grove_rgb_lcd/grove_rgb_lcd.py", line 46, in setRGB
bus.write_byte_data(DISPLAY_RGB_ADDR,4,r)
File "/usr/local/lib/python2.7/dist-packages/smbus_cffi-0.5.1-py2.7-linux-armv7l.egg/smbus/util.py", line 59, in validator
return fn(*args, **kwdefaults)
File "/usr/local/lib/python2.7/dist-packages/smbus_cffi-0.5.1-py2.7-linux-armv7l.egg/smbus/smbus.py", line 145, in write_byte_data
raise IOError(ffi.errno)
IOError: 121
Display does light up and says: Hellow World LCT Test but then the script exits
i2cdetect -y 1 after execution of the script:
root@pi-tijmen:/home/pi/Dexter/GrovePi/Software/Python/grove_rgb_lcd# i2cdetect -y 1
30: -- -- -- -- -- -- -- -- 38 39 -- -- -- -- 3e --
40: -- -- -- -- -- 45 -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
@RobertLucian
running the lcd.sh in Shell folder also errors:
root@pi-tijmen:/home/pi/Dexter/GrovePi/Software/Shell/Grove - LCD RGB Backlight# ./lcd.sh
Error: Write failed
Error: Write failed
Error: Write failed
Are you somehow running multiple scripts at the same time that access the same I2C device?
Iām having the same problem.
Using :
- Raspberry Pi 4 Model B (Linux raspberrypi 5.10.17-v7l+ #1403 SMP Mon Feb 22 11:33:35 GMT 2021 armv7l GNU/Linux)
- GrovePi+ HAT (updated as of 7th March 2021)
- Grove LCD RGB Backlight v4.0
- Temperature Humidity Sensor v1.2
Getting error 121
Please help.
import math
import datetime
import grovepi
from grove_rgb_lcd import *
try:
setRGB(255,255,255)
setText("Initializing...")
time.sleep(2)
sensor = 4
blue = 0
try:
[temp,humidity] = grovepi.dht(sensor,blue)
mytxt = "T = {}C H = {}% ";
if math.isnan(temp) == False and math.isnan(humidity) == False:
nnow = datetime.datetime.now().strftime("%X")
setText_norefresh(mytxt.format(temp,humidity) + nnow)
print(mytxt.format(temp,humidity) + nnow)
time.sleep(1)
except IOError as io_error:
print("io_error = " + str(io_error))
raise IOError
except KeyboardInterrupt:
setRGB(0,0,255)
setText("Exit OK")
except IOError as ioerror:
print(ioerror)
setRGB(255,0,0)
setText("IO Error")
