ROS Tutorial: Setup Map From House Plan Drawing
Thinking far ahead, I was wondering if discovery was the only way to develop a map.
ROS.org on Twitter suggested a “Setting up ROS Nav Stack” tutorial. Turns out the writer has other applicable tutorials, among them sensor fusion of odometry with BNO055 IMU for a two wheel differential bot, and this tutorial:
Wow, what a great find!
I can see how Carl/Dave would find that immensely helpful.
I can also see @KeithW being all over this once you figure out how to get it working.
Fantastic!
:+1:
Interesting. I wonder how things like the chairs (which have solid lines on the blueprints) will impact navigation, since at the robot level it will just see the legs. From a navigation standpoint it won’t go there. But I wonder how much it interferes with localization, since the lidar returns wouldn’t be consistent with the map.
One way to find out I guess.
<edit - I had written this reply shortly after you initially posted. But somehow I didn’t actually post it>
/K
If “chairs” or other furniture/appliances are shown on the blueprint, it’s either a “built-in” or “for reference only”.
Built-ins should be solid objects, and movable furniture should not be included unless sufficiently massive and/or immovable.
Furniture also implies that the robot can discover and learn if the furniture moves.
Interesting!
At least in the example it does look like they have movable “for reference” items on the blueprint. And I think the conversion ends up making these appear to be a solid obstacle.
I know it is possible to pull the .pgm file into an image editor and remove/add obstacles and just tidy things up in general. I’ve done that in the past.
/K
Addendum - was experimenting with that this evening. You can actually use IrfanView (which has long been my favorite image viewer on Windows) to edit .pgm files. I hadn’t realized there is a “paint” menu for very simple bitmap manipulation. IrfanView is a free download for non-commercial use, and has been around for a very long time, so I’ve trusted that it doesn’t contain malware. https://www.irfanview.com/
