I am a grovepi newbie. I have been able to get the led sensor and temperature sensor to work with python. But based on code found on the internet. I have not been able to test the sensors with the sample projects found on the pi raspberry itself. Any idea why that is the case?
Hello @BaranD
We would need more specific details in order to help.
First, are you running Raspbian for Robots, or Raspbian?
Do you have a GrovePi+ or a Grove Base Hat?
I have given it another try. And noticed I was trying to execute the OLED projects with the Grove-LCD RGB Backlight, but that doesn’t work. So in the mean time I have tried other sensors and they all work. I am now having trouble using the LCD RGB Backlight.
F.e. I am trying the Advanced_RGB_LCD_TempAndHumidity project but it does not say in which port I have to plug in the RGB backlight port. Currently the output of the DHT sensor is printed in the command line interface. Where do I have to plugin the LCD RGB backlight so that DHT sensors outputs it on the LCD?
