I have just built the GoPiGo and setup the Raspbian for Robots (Jesse 2016.05.16).
I have logged into the system using VNC and successfully setup the Wifi. I am able to get an IP from my local network and ping out.
The problem is that as soon as I reboot, the settings disappear.
I checked the /etc/wpa_supplicant/wpa_supplicant.conf file after I had connected to my network, and the SSID etc of my network appeaered in it. But as soon as I reboot the file resets again.
I have never seen that one before, but let’s try to figure this out.
check if there’s a wpa_supplicant.conf in the /boot directory
With the latest changes that the Raspberry Pi Foundation did to Jessie, there might be an issue with this. For now, it’s the only thing that comes to mind.
