While running the basic_test_all.py program, if I run the servo test (type ‘b’), the GPG LEDs (the 2 red ones at the front) will change intensity, and if I run the LED test (type ‘l’), the servo will move, in addition to the LEDs erratically changing intensity.
I’ve also made a stand-alone LED test program, and when I run it, the servo moves.
Here’s the code (basically copied the LED section from basic_test_all.py):
from gopigo import *
for i in range(256):
print led(LED_L,i)
print led(LED_R,i)
time.sleep(.01)
print led(LED_L,0)
print led(LED_R,0)
Any ideas? I’ve updated firmware, redownloaded GoPiGo from github, fresh batteries, etc. I’m starting to believe that this is a hardware problem.
