I bought a GoPiGo2 from one of your resellers in Europe, and the pins that are to connect the servo motor cable were separate from the GoPiGo2. I tried to find instructions in your website on if they do need soldering and I couldn’t, in all your tutorials the pins seem already attached. I tried to solder it myself and either I got it damaged or it was damaged beforehand, because it doesn’t work. Are there any instructions on how to properly solder it? LEDs also do not work, while wheel motors work fine.
It looks like this is mechanically damaged, the pins have been ripped apart and off the GoPiGo. If it was shipped this way, you should contact your distributor about a replacement.
Thanks, I’ll let the distributor know! I hope I get a replacement
