While I don’t need a GoPiGo3 simulator for remote code development, someone mentioned remote code development and got me thinking about it.
I put together the trappings of a simulated GoPiGo3 that allows testing a basic robot with a distance sensor:
Where a program normally has:
import easygopigo3
the developer can add:
# Uncomment import of sim.easygopigo3 or easygopigo3 as appropriate
import sim.easygopigo3 as easygopigo3
# import easygopigo3
run the program, and see any print statements as in:
$ ./myRobot.py
Log: Starting myRobot.py main()
Log: Instantiate EasyGoPiGo3 object
Log: Instantiate distance sensor object
Log: set_robot_constants(66.4)
Log: save_robot_constants()
Log: load_robot_constants()
Log: volt() returns 9.5v
Log: set_speed(150)
Log: get_speed() returns 150 DPS
Log: reset_speed()
Log: get_speed() after reset returns 300 DPS
Log: forward() for 2 seconds
Log: stop()
Log: egpg.ds.read_mm() returned 914.4 mm
Log: drive_cm(10.16)
Log: egpg.ds.read_mm() returned 814.4 mm
Log: egpg.ds.read_inches() returned 31.9 inches
Log: drive_inches(-4.0)
Log: egpg.ds.read_inches() returned 35.8 inches
Log: End myRobot.py main()
and the sim.log contains:
more sim.log
2020-11-22 23:30|[gopigo3.py.<module>]sim.gopigo3 imported
2020-11-22 23:30|[easygopigo3.py.<module>]sim.easygopigo3 imported
2020-11-22 23:30|[gopigo3.py.__init__]Simulated GoPiGo3 object instantiated
2020-11-22 23:30|[easygopigo3.py.load_robot_constants]sim.easygopigo3.load_robot_constants() called
2020-11-22 23:30|[easygopigo3.py.set_robot_constants]sim.easygopigo3.set_robot_constants(66.6,116.6) called
2020-11-22 23:30|[easygopigo3.py.set_speed]sim.easygopigo3.set_speed(300) called
2020-11-22 23:30|[simDataJson.py.saveData]** simData 'motor_limit_left' = 300 updated **
2020-11-22 23:30|[simDataJson.py.saveData]** simData 'motor_limit_right' = 300 updated **
2020-11-22 23:30|[easygopigo3.py.__init__]Simulated EasyGoPiGo3 instatiated
2020-11-22 23:30|[easygopigo3.py.init_distance_sensor]sim.easygopigo3.init_distance_sensor(port=I2C) called
2020-11-22 23:30|[easy_distance_sensor.py.__init__]sim.di_sensors.EasyDistanceSensor object instantiated
2020-11-22 23:30|[distance_sensor.py.__init__]Initializing sim.di_sensor.distance_sensor.DistanceSensor() object
2020-11-22 23:30|[simDataJson.py.saveData]** simData 'rangeSensor_mm' = 914.4 updated **
2020-11-22 23:30|[easygopigo3.py.save_robot_constants]sim.easygopigo3.save_robot_constants() called
2020-11-22 23:30|[easygopigo3.py.set_speed]sim.easygopigo3.set_speed(150) called
2020-11-22 23:30|[simDataJson.py.saveData]** simData 'motor_limit_left' = 150 updated **
2020-11-22 23:30|[simDataJson.py.saveData]** simData 'motor_limit_right' = 150 updated **
2020-11-22 23:30|[easygopigo3.py.get_speed]sim.easygopigo3.get_speed() called
2020-11-22 23:30|[easygopigo3.py.reset_speed]sim.easygopigo3.reset_speed() called
2020-11-22 23:30|[easygopigo3.py.forward]sim.easygopigo3.forward() called
2020-11-22 23:30|[simDataJson.py.saveData]** simData 'motor_dps_left' = 1000 updated **
2020-11-22 23:30|[simDataJson.py.saveData]** simData 'motor_dps_right' = 1000 updated **
2020-11-22 23:30|[easygopigo3.py.stop]sim.easygopigo3.stop() called
2020-11-22 23:30|[simDataJson.py.saveData]** simData 'motor_dps_left' = 0 updated **
2020-11-22 23:30|[simDataJson.py.saveData]** simData 'motor_dps_right' = 0 updated **
2020-11-22 23:30|[easygopigo3.py.drive_cm]sim.easygopigo3.drive_cm(10) called
2020-11-22 23:30|[simDataJson.py.saveData]** simData 'rangeSensor_mm' = 814.4 updated **
2020-11-22 23:30|[easygopigo3.py.drive_inches]sim.easygopigo3.drive_cm(-4.0) called
2020-11-22 23:30|[easygopigo3.py.drive_cm]sim.easygopigo3.drive_cm(-10.16) called
2020-11-22 23:30|[simDataJson.py.saveData]** simData 'rangeSensor_mm' = 916.0 updated **
This is the test program:
#!/usr/bin/env python3
# Uncomment import of sim_easygopigo3 or easygopigo3 as appropriate
from time import sleep
import traceback
def testEachMethod(egpg):
print("Log: set_robot_constants(66.4)")
egpg.set_robot_constants(66.6, 116.6)
print("Log: save_robot_constants()")
egpg.save_robot_constants()
print("Log: load_robot_constants()")
egpg.load_robot_constants()
print("Log: volt() returns {}v".format(egpg.volt()))
print("Log: set_speed(150)")
egpg.set_speed(150)
print("Log: get_speed() returns {} DPS".format(egpg.get_speed()))
print("Log: reset_speed()")
egpg.reset_speed()
print("Log: get_speed() after reset returns {} DPS".format(egpg.get_speed()))
print("Log: forward() for 2 seconds")
egpg.forward()
sleep(2)
print("Log: stop()")
egpg.stop()
print("Log: egpg.ds.read_mm() returned {} mm".format(egpg.ds.read_mm()))
print("Log: drive_cm(10.16)")
egpg.drive_cm(10)
print("Log: egpg.ds.read_inches() returned {} inches".format(egpg.ds.read_inches()))
print("Log: drive_inches(-4.0)")
egpg.drive_inches(-4.0)
def main():
print("Log: Starting myRobot.py main()")
try:
print("Log: Instantiate EasyGoPiGo3 object")
egpg = easygopigo3.EasyGoPiGo3(use_mutex=True)
print("Log: Instantiate distance sensor object")
egpg.ds = egpg.init_distance_sensor()
except Exception as e:
print("Log: {}".format(str(e)))
exit(1)
try:
traceback.print_exc()
exit(1)
print("Log: End myRobot.py main()")
if __name__ == "__main__":
main()
The simulator lives in a folder named ‘sim’ along side the user program to test:
$ls -1
myRobot.py
sim
sim.log
Also there is a program to list the GoPiGo3 simulated data content (in sim/simData.json):
$ sim/listSimData.py
vBatt:9.5
motor_limit_left:300
motor_limit_right:300
motor_dps_left:0
motor_dps_right:0
rangeSensor_mm:916.0
Note: it isn’t simulating movement over time - would have to launch a subprocess for that and I didn’t really want to get that tricky.
Just an idea if someone wanted to flesh out a simulator for remote code testing prior to getting access to a bot.
It is possible - would take a bit of work.
To get it download the gzipped tar file SimGoPiGo3.tgz
