I’m wondering if the dpressure sensor is capable to receive water in is tubing instead of water.
In other words, is the measurement chamber waterproof?
Thank you for helping
Sebastien
Sebastien
Hey Sebastien, the dPressure is not water-proof. Getting water in the dPressure will damage it.
thank you for ultrafast response!
Do you have a device that could do the job?
Thank U
Sebastien
Hi @sebgab67,
Lego Mindstorms doesn’t have a device for measuring the water pressure.
If you need a pressure sensor for any other applications, then I suggest you use the following sensor:
https://www.seeedstudio.com/Water-Pressure-Sensor-G1%2F4-1.2MPa-p-2887.html
Please tell us if this is useful for you.
Hello
Thank you for the help.
I will look at this sensor
Best regards
Sebastien
