[SOLVED] GOPIGO 3 Temperature Pressure Humidity Sensor
I bought a Temperature Pressure Humidity sensor for the GOPIGO3 but don’t know how to use it as Bloxter does not yet support it.
Is there a way to use it manually using Python?
Do I need to connect the two sensor outputs to the two I2C ports?
Hello @terryandunha
Bloxter does support it, starting with version 1.2
What version are you running?
You can update your DexterOS by following these instructions
Thanks Cleo! (It worked after I updated the OS.)
Yeah!
Thanks for letting me know you’re up and running.
