[SOLVED] Grove Temperature and Humidity Mini Sensor giving wrong readings
The Grove Temperature and Humidity Mini sensor is giving strange readings using the temp_hum_example.py script. E.g it is giving readings of 217C and 150% humidity. The script does mention in the comments that this component is not well supported.
Any ideas why the reading are wrong?
Sami
By the way, have re-tested this sensor with Raspian for Robots, and is working now. Was not working properly using normal Raspian and following the Setup Software guide, and then updating the firmware.
Hi @s.maam,
I’m glad to hear you figured it out.
Though, I want a confirmation from you.
You said you’re using the Grove Temperature and Humidity Mini Sensor.
I suppose you’re referring to this one, correct?
This topic was automatically closed after 25 hours. New replies are no longer allowed.
