Dear team,
I have bought GrovePi and start to test it using provided Scratch examples. The LED example was success. However, the LCD example always fail with an error "GrovePi Scratch: Error <type ‘exceptions.ImportError’>.
Dear team,
Hi @sramctc,
Does it work if you just run a python example for the LCD? Here’s a link to a bunch of LCD examples.
Thanks a lot
Here is the “Test and troubleshooting” log
Check space left
/dev/root 27G 5.3G 21G 21% /
devtmpfs 460M 0 460M 0% /dev
tmpfs 464M 0 464M 0% /dev/shm
tmpfs 464M 13M 452M 3% /run
tmpfs 464M 0 464M 0% /sys/fs/cgroup
/dev/mmcblk0p6 68M 22M 47M 32% /boot
tmpfs 93M 0 93M 0% /run/user/1000
/dev/mmcblk0p5 30M 454K 28M 2% /media/pi/SETTINGS
Check for dependencies
python 2.7.13-2 install ok installed
python-pip 9.0.1-2+rpt2 install ok installed
git 1:2.11.0-3+deb9u3 install ok installed
libi2c-dev 3.1.2-3 install ok installed
python-serial 3.2.1-1 install ok installed
python-rpi.gpio 0.6.3~stretch-1 install ok installed
i2c-tools 3.1.2-3 install ok installed
python-smbus 3.1.2-3 install ok installed
arduino 2:1.0.5+dfsg2-4.1 install ok installed
minicom 2.7-1.1 install ok installed
find: ‘/run/user/1000/gvfs’: Permission denied
wiringPi Not Found (ERR)
I2C still in blacklist (ERR)
SPI still in blacklist (ERR)
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
gpio version: 2.44
Copyright (c) 2012-2017 Gordon Henderson
Raspberry Pi Details:
Type: Unknown13, Revision: 03, Memory: 1024MB, Maker: Sony
* Device tree is enabled.
*--> Raspberry Pi 3 Model B Plus Rev 1.3
* This Raspberry Pi supports user-level GPIO access.
Check the /dev folder
i2c-1
ttyAMA0
USB device status
Bus 001 Device 004: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/3p, 480M
|__ Port 1: Dev 4, If 0, Class=Vendor Specific Class, Driver=lan78xx, 480M
Raspbian for Robots Version
Hostname
raspberrypi
Checking for Atmega chip
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Checking I2C bus 1
00: 03 04 -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- 3e --
60: -- -- 62 -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Checking for firmware version
GrovePi has firmware version: 1.2.7
Hi @sramctc,
It looks like you have an import error in Scratch - it’s not that the GrovePi isn’t working or accessible.
The GrovePi and the Grove RGB LCD work just fine, so if there’s anything wrong, then it must be coming from Scratch.
@cleoqc, could it be caused by some uninstalled dependency?
hello @sramctc
Could you tell me if you are running Raspbian for Robots, or did you install the GrovePi library on your own SD card? Also, are you on Jessie or Stretch?
Dear cleoqc,
As I remember,
Hello @cleoqc
I’ve just started using Raspbian for Robots with GrovePi+ and I also encountered the same worrying LCD exception as @sramctc (when running both Scratch and Python built-in examples provided), but the LCD does work okay when running the grove_rgb_lcd.py script from GitHub.
I’m so relieved to discover this thread and that the cause has been found to be software related.
However, I’ve been asked to run a Scratch coding workshop for children in three weeks time to demonstrate the GrovePi’s capabilities and the LCD is such an important component.
Do you have any idea of the timescale for a fix?
Many thanks in advance
The fix is in. If you do a DI Update on your Raspbian for Robots, the fix will be installed on your SD cards.
Apologies for the hiccup,
