I am using a GrovePi starterkit, and have followed all installation guides.
However, when i try some of the example projects (“sudo python grove_led_blink.py”) i get the following error messages:
Any ideas of what the problem might be and how to solve it?
//Stefan
di_i2c (di_i2c.py) is part of the Raspbian For Robots RFR_Tools installed by default in the Raspbian For Robots image.
On my R4R Stretch image, it exits in ~/Dexter/lib/Dexter/RFR_Tools/miscellaneous/ and …miscellaneous/build/lib/ and …miscellaneous/build/lib.linux-armv7l-2.7 and possibly in
‘/usr/local/lib/python2.7/dist-packages/Dexter_AutoDetection_and_I2C_Mutex-0.0.0-py2.7.egg’,
and
‘/usr/local/lib/python3.5/dist-packages/Dexter_AutoDetection_and_I2C_Mutex-0.0.0-py3.5.egg’,
It also gets installed when you install di_sensors see: https://github.com/DexterInd/DI_Sensors/tree/master/Install
Hi Stefan
If you did the installation per the booklet that comes with the GrovePi+ kit, it is not complete.
Please install using
It should fix your problem
Thanks a lot!
After running that, everything works as it should!
//Stefan
