Hi All,
I’m using an RPi 4 with raspbian installed. I have attempted to reinstall grovepi twice now; the quick method way and walk through manual way and both were successful. All details below.
OS:
PRETTY_NAME=“Raspbian GNU/Linux 10 (buster)”
NAME=“Raspbian GNU/Linux”
VERSION=“10 (buster)”
The Error I receive:
pi@raspberrypi:~/pico/Seeed_Python_SGP30/examples $ python sgp30_simpleread.py
File “sgp30_simpleread.py”, line 3, in
from grove.i2c import Bus
ImportError: No module named grove.i2c
The code:
import seeed_sgp30
import grovepi
sgp30 = seeed_sgp30.grove_sgp30(Bus())
data = sgp30.read_measurements()
co2_eq_ppm, tvoc_ppb = data.data
print("\r tVOC = {} ppb CO2eq = {} ".format(
tvoc_ppb, co2_eq_ppm))
Troubleshoot All log.txt:
Check space left
/dev/root 30G 2.6G 26G 10% /
devtmpfs 1.8G 0 1.8G 0% /dev
tmpfs 2.0G 0 2.0G 0% /dev/shm
tmpfs 2.0G 8.4M 1.9G 1% /run
tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
/dev/mmcblk0p1 253M 53M 200M 21% /boot
tmpfs 391M 0 391M 0% /run/user/1000
Check for dependencies
python 2.7.16-1 install ok installed
python-pip 18.1-5+rpt1 install ok installed
git 1:2.20.1-2+deb10u1 install ok installed
libi2c-dev 4.1-1 install ok installed
python-serial 3.4-4 install ok installed
python-rpi.gpio 0.7.0~buster-1 install ok installed
i2c-tools 4.1-1 install ok installed
python-smbus 4.1-1 install ok installed
dpkg-query: no packages found matching arduino
dpkg-query: no packages found matching minicom
scratch 1.4.0.6~dfsg1-6 install ok installed
wiringPi Not Found (ERR)
I2C still in blacklist (ERR)
SPI still in blacklist (ERR)
I2C-dev already there
i2c-bcm2708 already there
spi-dev already there
Hardware revision
./software_status.sh: line 78: gpio: command not found
Check the /dev folder
i2c-1
ttyAMA0
USB device status
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
Raspbian for Robots Version
Hostname
raspberrypi
Checking for Atmega chip
User configuration file is "/home/pi/.avrduderc"
Using Port : unknown
Using Programmer : gpio
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Programmer Type : GPIO
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Checking I2C bus for devices
Checking I2C bus 0
Error: Could not open file /dev/i2c-0' or /dev/i2c/0’: No such file or directory
Checking I2C bus 1
40: – -- – -- 44 45 – -- – -- – -- – -- – --
50: – -- – -- – -- – -- 58 – -- – -- – -- –
70: – -- – -- – -- – --
Checking for firmware version
GrovePi has firmware version: 1.3.0
