pi@TelePi:~/projects/python $ sudo pip3 install grovepi
Collecting grovepi
Downloading grovepi-1.0.0.tar.gz
Complete output from command python setup.py egg_info:
<class 'OSError'>
make sure you have [package_description.rst] file in the same directory as [setup.py]
File "<string>", line 1, in <module>
File "/tmp/pip-build-jt3h92sr/grovepi/setup.py", line 51, in <module>
long_description = description,
NameError: name 'description' is not defined
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-jt3h92sr/grovepi/
Should mention, I used the git version instead and that was fine.
Hi @ghidera2000,
That’s a really good catch. Kudos!
I’ve created a PR and by tomorrow this should be fixed:
Hi @ghidera2000,
It’s now fixed. Please update the package with pip and it should now work.
This topic was automatically closed after 44 hours. New replies are no longer allowed.
