Hey Karen,
Thanks for your post. I gave writing a Python version of the library a go in order to get it to work.
It almost works, except I am having a few problems with the output of the device.
Here’s the code I’ve put together. Apologies for any rookie errors, this is effectively my foray into Python…
#!/usr/bin.env python
# Python translation of Arduino code provided by Frankie.Chu
# for GrovePi+ module.
# Hardware: Grove - 3-Axis magnetometer/3-axis accelometer (LMS303D)
import smbus
import time
import math
import RPi.GPIO as GPIO
import struct
rev = GPIO.RPI_REVISION
if rev == 2 or rev == 3:
bus = smbus.SMBus(1)
else:
bus = smbus.SMBus(0)
### LSM303 Address ###
LSM303D_ADDR = 0x1E # Assuming SA0 grounded
### LSM303 Register definitions ###
TEMP_OUT_L = 0x05
TEMP_OUT_H = 0x06
STATUS_REG_M = 0x07
OUT_X_L_M = 0x08
OUT_X_H_M = 0x09
OUT_Y_L_M = 0x0A
OUT_Y_H_M = 0x0B
OUT_Z_L_M = 0x0C
OUT_Z_H_M = 0x0D
WHO_AM_I = 0x0F
INT_CTRL_M = 0x12
INT_SRC_M = 0x13
INT_THS_L_M = 0x14
INT_THS_H_M = 0x15
OFFSET_X_L_M = 0x16
OFFSET_X_H_M = 0x17
OFFSET_Y_L_M = 0x18
OFFSET_Y_H_M = 0x19
OFFSET_Z_L_M = 0x1A
OFFSET_Z_H_M = 0x1B
REFERENCE_X = 0x1C
REFERENCE_Y = 0x1D
REFERENCE_Z = 0x1E
CTRL_REG0 = 0x1F
CTRL_REG1 = 0x20
CTRL_REG2 = 0x21
CTRL_REG3 = 0x22
CTRL_REG4 = 0x23
CTRL_REG5 = 0x24
CTRL_REG6 = 0x25
CTRL_REG7 = 0x26
STATUS_REG_A = 0x27
OUT_X_L_A = 0x28
OUT_X_H_A = 0x29
OUT_Y_L_A = 0x2A
OUT_Y_H_A = 0x2B
OUT_Z_L_A = 0x2C
OUT_Z_H_A = 0x2D
FIFO_CTRL = 0x2E
FIFO_SRC = 0x2F
IG_CFG1 = 0x30
IG_SRC1 = 0x31
IG_THS1 = 0x32
IG_DUR1 = 0x33
IG_CFG2 = 0x34
IG_SRC2 = 0x35
IG_THS2 = 0x36
IG_DUR2 = 0x37
CLICK_CFG = 0x38
CLICK_SRC = 0x39
CLICK_THS = 0x3A
TIME_LIMIT = 0x3B
TIME_LATENCY = 0x3C
TIME_WINDOW = 0x3D
ACT_THS = 0x3E
ACT_DUR = 0x3F
### Mag scales ###
MAG_SCALE_2 = 0x00 # full-scale is +/- 2 Gauss
MAG_SCALE_4 = 0x20 # +/- 4 Guass
MAG_SCALE_8 = 0x40 # +/- 8 Guass
MAG_SCALE_12 = 0x60 # +/- 12 Guass
ACCEL_SCALE = 2 # +/- 2g
X = 0
Y = 1
Z = 2
def twos_comp(val, bits):
# Calculate the 2s complement of int:val #
if(val&(1<<(bits-1)) != 0):
val = val - (1<<bits)
return val
# return val if val < 32768 else val - 65536
class accelcomp:
mag = [0,0,0]
accel = [0,0,0]
tiltcomp = [0,0,0]
heading=0
headingDegrees=0
tiltHeading=0
tiltHeadingDegrees=0
def __init__(self):
whoami = bus.read_byte_data(LSM303D_ADDR, WHO_AM_I)
if(whoami == 0x49):
bus.write_byte_data(LSM303D_ADDR, CTRL_REG1, 0x57) # 0x57 = ODR=50hz, all accel axes on ## maybe 0x27 is Low Res?
bus.write_byte_data(LSM303D_ADDR, CTRL_REG2, (3<<6)|(0<<3)) # set full scale +/- 2g
bus.write_byte_data(LSM303D_ADDR, CTRL_REG3, 0x00) # no interrupt
bus.write_byte_data(LSM303D_ADDR, CTRL_REG4, 0x00) # no interrupt
bus.write_byte_data(LSM303D_ADDR, CTRL_REG5, (4<<2)) # 0x10 = mag 50Hz output rate
bus.write_byte_data(LSM303D_ADDR, CTRL_REG6, MAG_SCALE_2) # Magnetic Scale +/1 1.3 Guass
bus.write_byte_data(LSM303D_ADDR, CTRL_REG7, 0x00) # 0x00 continuous conversion mode
def getMag(self):
self.mag[X] = twos_comp(bus.read_byte_data(LSM303D_ADDR, OUT_X_H_M) << 8 |
bus.read_byte_data(LSM303D_ADDR, OUT_X_L_M), 16)
self.mag[Y] = twos_comp(bus.read_byte_data(LSM303D_ADDR, OUT_Y_H_M) << 8 |
bus.read_byte_data(LSM303D_ADDR, OUT_Y_L_M), 16)
self.mag[Z] = twos_comp(bus.read_byte_data(LSM303D_ADDR, OUT_Z_H_M) << 8 |
bus.read_byte_data(LSM303D_ADDR, OUT_Z_L_M), 16)
def getAccel(self):
accel = [0,0,0]
accel[X] = twos_comp(bus.read_byte_data(LSM303D_ADDR, OUT_X_H_A) << 8 |
bus.read_byte_data(LSM303D_ADDR, OUT_X_L_A), 16)
accel[Y] = twos_comp(bus.read_byte_data(LSM303D_ADDR, OUT_Y_H_A) << 8 |
bus.read_byte_data(LSM303D_ADDR, OUT_Y_L_A), 16)
accel[Z] = twos_comp(bus.read_byte_data(LSM303D_ADDR, OUT_Z_H_A) << 8 |
bus.read_byte_data(LSM303D_ADDR, OUT_Z_L_A), 16)
for i in range(X, Z+1):
self.accel[i] = accel[i] / math.pow(2, 15) * ACCEL_SCALE
def getHeading(self):
self.heading = math.atan2(self.mag[X], self.mag[Y])
if self.heading < 0:
self.heading += 2*math.pi
if self.heading > 2*math.pi:
self.heading -= 2*math.pi
self.headingDegrees = round(math.degrees(self.heading),2)
def getTiltHeading(self):
truncate = [0,0,0]
truncate[i] = math.copysign(min(math.fabs(self.accel[i]), 1.0), self.accel[i])
try:
pitch = math.asin(-1*truncate[X])
roll = math.asin(truncate[Y]/math.cos(pitch)) if abs(math.cos(pitch)) >= abs(truncate[Y]) else 0
# set roll to zero if pitch approaches -1 or 1
self.tiltcomp[X] = self.mag[X] * math.cos(pitch) + self.mag[Z] * math.sin(pitch)
self.tiltcomp[Y] = self.mag[X] * math.sin(roll) * math.sin(pitch) + \
self.mag[Y] * math.cos(roll) - self.mag[Z] * math.sin(roll) * math.cos(pitch)
self.tiltcomp[Z] = self.mag[X] * math.cos(roll) * math.sin(pitch) + \
self.mag[Y] * math.sin(roll) + \
self.mag[Z] * math.cos(roll) * math.cos(pitch)
self.tiltHeading = math.atan2(self.tiltcomp[Y], self.tiltcomp[X])
if self.tiltHeading < 0:
self.tiltHeading += 2*math.pi
if self.tiltHeading > 2*math.pi:
self.tiltHeadingDegrees = round(math.degrees(self.tiltHeading),2)
except Exception:
print "AccelX {}, AccelY {}".format(self.accel[X], self.accel[Y])
print "TruncX {}, TruncY {}".format(truncate[X], truncate[Y])
print "Pitch {}, cos(pitch) {}, Bool(cos(pitch)) {}".format(pitch, math.cos(pitch), bool(math.cos(pitch)))
def isMagReady(self):
temp = bus.read_byte_data(LSM303D_ADDR, STATUS_REG_M) & 0x03
return temp
def update(self):
self.getAccel()
self.getMag()
self.getHeading()
self.getTiltHeading()
if __name__ == '__main__':
from time import sleep
lsm = accelcomp()
print ' Accelerometer || Compass || Heading'
print ' x | y | z || x | y | z || calc | tilt corrected |'
lsm.getAccel()
while not bool(lsm.isMagReady()):
print "Not Ready!"
sleep(.01)
lsm.getMag()
lsm.getHeading()
lsm.getTiltHeading()
print '{0:.3f} |{1:.3f} |{2:.3f} ||{3:6} |{4:6} |{5:6} || {6:6} deg | {7:6} deg |'.format(
lsm.accel[X], lsm.accel[Y], lsm.accel[Z], lsm.mag[X], lsm.mag[Y], lsm.mag[Z], lsm.headingDegrees, lsm.tiltHeadingDegrees)
sleep(.5)
Running my library as main for testing gives me data like the following:
0.022 |-0.012 |1.056 || 876 | -1119 | 5788 || 141.94 deg | 305.58 deg |
0.027 |-0.011 |1.052 || 919 | -1128 | 5826 || 140.83 deg | 305.62 deg |
0.026 |-0.010 |1.053 || 903 | -1108 | 5777 || 140.82 deg | 305.61 deg |
0.024 |-0.009 |1.054 || 914 | -1140 | 5790 || 141.28 deg | 305.57 deg |
0.024 |-0.010 |1.056 || 895 | -1122 | 5801 || 141.42 deg | 305.42 deg |
0.024 |-0.010 |1.055 || 905 | -1088 | 5747 || 140.25 deg | 306.69 deg |
0.022 |-0.008 |1.057 || 900 | -1106 | 5748 || 140.86 deg | 306.15 deg |
It may be difficult to see the problems from the output directly:
1/ The Accelerometer at rest shows values that look almost correct; however the resting Z-direction gives a reading greater than 1g. This is true for the X and Y axes when rotated to be parallel to the gravity vector field. This causes math errors with asin. I’ve truncated these values in the tilt corrected code to avoid these errors.
2/ The compass gains an error over a full rotation: Facing Magnetic North (as determined by my phone), the value outputted is roughly correct. As the sensor is rotated clockwise, the error increases almost linearly to about 15 degree error at 200 degrees, at which point it jumps up to about 30 degrees off at 250 degrees, then rapidly comes back to within 3 degrees at North again.
I’ve attached a spreadsheet of the trials performed and the resulting graph.
I can’t see any problem with the code; the maths are equivalent to the c++ code I was working from. I’ve examined the LSM303D datasheet closely, but cannot find any reason for these discrepancies. Could this be an issue with the device itself, or is there something in my code I’ve missed?
