Hi there, I wonder is that many sensors may make the grovePi impossible to provice current (using the recommended rpi DC adapter) or any other possible problem you may detect
thanks in advance
thanks in advance
Hi @annlee,
The only sensors you would be connecting to the GrovePi are those that have the following identifiers in your diagram:
The rest of them will only go through the Raspberry Pi, so yes, they can all get the required current from the GrovePi, provided you have a good power supply for the Raspberry Pi.
yes, I will be using the official rpi power supply
I just was worried that since each sensor has a consumption, wouldn’t be enough to feed that many sensors, but I guess you think wont be problem
Well, yeah, those sensors you showed me won’t draw too much current, so you’re safe. I’m not sure about others though.
I’m gonna close this thread now if that’s okay with you.
great, you can close, thanks
This topic was automatically closed after 42 hours. New replies are no longer allowed.
